TSD 402
p_c
4 Mar 2005
I have a system with a TSD402 main control panel and a second small panel in the entrance hallway. Because of extensive decorating work I need to disconnect and remove the hallway panel. My plan is to cut the power from the system and wait until the battery is exhausted and the system dead then remove the panel. I assume that the settings/codes etc will not be saved and the sytem will need to be reset when powered up. My questions are:
1) Is this the most sensible approach.
2) Does anyone have installation information which will allow me to reset the system as I only have the general user manual.
you have a panel sand remote keypad.
your idea is not a good one, dont do it.
if you know the engineers code you can put it into engineers mode.
if you don't know the engineers code, open the remote keypad, enter your code to the main panel to silence it, note what goes where (dont lose it) remove keypad do what you want put it back reconnect it re enter your code
hi
also just another point to consider, if you kill all power you will set off the onboard battery in the bell outside, that wont silence until it goes flat or you reinstate power.
