Twin and Earth
I wonder what effect the cryogenic ( freezing ) process will have had on the insulation properties of the plastics used.
If the new and ( NOT ) improved terminals have been made out of copper then they will not be as mechanically strong as the brass originally used leading to failure of the termination as the soft copper screw threads deform over time.
At least the price will prevent most people buying them.
That socket's no good anyway, everybody knows that you're supposed to use round pin plugs and sockets on your hifi, so that the electrons can't hide in the corners! :P
I actually had a customer tell me this once, I don't know how I kept a straight face!
Russ even gives instruction how to install a HiFi ring main. See the link on that page that Spark 123 mentioned.[/quote]
That cable is cheap at £9/m, try this: clicky
If that cable is such pure copper, why, if it's the equivelant of 6.5mm sq cable, is the current rating less than 4mm and barely more than 2.5mm?
You could put some 25mm in for that price
(I'm aware it's a farce)
Yes, but he can only con people who want to be conned. And it's a form of wealth re-distribution. Nobody pays that sort of money for cable and accessories if they can barely afford it.
