Twist or not ?
19 Jun 2003
Hi all, should you twist the conductors together before inserting them into the electrical socket terminals ? I've been told yes and no, which is correct.
The way I do it I bend it U-shape hook and when screw in the terminals it can't come out,don't know what is the correct way.
I am sorry i have to slightly disagree, If you have two cables going in then put them in strait, if it is one then as masona said bend it into a u sort of shape.
It used to be common to twist them but this can cause them to break
