twisting of copper core
2 Feb 2007
Hi
I'm replacing a length of 2.5 cable to a socket where it has been drilled though (previous owners i will add), is there a requirement for the wires to be twisted together when terminated?
thanks.
NO!!
The exact opposite infact.
Twisting the ends together weakens the copper, and just causes more work when it comes to fault finding time.
No requirement at all, in fact I don't like conductors twisted together.
Imagine the terminal screw putting all its pressure on one conductor due to the twist. I've seen many cases of snapped conductors due to this.
I prefer them to enter the terminal side by side and have equal pressure exerted on them.
No - It weakens the cable if you twist - The copper work hardens and becomes 'brittle'.
Thank you very much for your replies from the 3 of you. I hoped that's what you would say. I have tried twisting them and they broke and with the new Mk socket I'm putting on they don't fit in the terminal location (it has a spur off the ring socket) even if twisted tight - and as you point out to test/fault find later causes a headache. What threw me is every other socket in the house (1974) has twisted wires.
Would this till be the case with 3 as said in my above reply, for a spur as three won't sit side by side, one will have to go on top?
Yep keep them all straight.
I think the twisting of conductor ends dates back to when stranded imperial cables were used.
Old habits die hard.
"Mr. Twisty" installed the original electrics in my house. It has been a PIA making changes, or even doing the PI. In some cases I found about 10cm of cpc twisted together!
It's a long time since I studied materials physics, however IIRC "work hardening" initially strengthens the metal due to removal of grain boundaries. I believe it only becomes brittle after repeated damage.
