So if you were to plot temperature over time using these axes, what sort of shape would you get?
Something with no resemblance whatsoever to your original image - I think even you realise that now
So hysteresis loops cannot arise because of a lag?
I doubt it - they are different phenomena.
OK, take this situation. You set the stat at 20˚C and leave it for a while.
Lag means that regardless of what state the system started, there will be delays, and it will take a long time to reach a stable temperature - it
may (depending on a load of factors) not actually reach a stable temperature, but cycle around the set point; or it
may settle to a stable temperature (the latter is actually quite achievable with electric heating and a burst mode controller). But regardless of whether it was previously cold, or you'd previously had it set to (say) 25˚C it will settle at the same point.
Hysteresis means that the final state the system settles at depends on whether it was previously cold or hot - so it might settle at (say) 18˚ if previously cold, or 22˚ if previously hot.
Two very different effects - and barring dead bands in the stat, hysteresis isn't an issue for domestic heating systems.
And I will point out that the heating element is not the whole system, you have shown the typical blinkered attitude that because a radiator is small in thermal mass, that it doesn't suffer lag and overshoot - once combined with the rest of the components needed to make it work, that is no longer the case.
And now much does it exhibit compared to a stone or concrete floor? How quickly does the latter respond to an acute need for heating, or an acute disappearance of the need for heating?
Well a wet system will heat the slab quite quickly - having 10s of kW of boiler behind it gives a distinct advantage over an electric system with a few hundred W or couple of kW. But speaking of some of the actuators, (from memory) some can take TWO minutes between application of a signal and starting to open, and if they've been open for a while, can take FIVE minutes before starting to close and SEVEN minutes to fully close. When you've got these on heat/cool air handlers it can cause some issues - and one we had was that the temperature could overshoot enough, and for long enough, that it would switch modes (eg start cooling while the heating valve was still open). Originally they were installed with mechanical stats, and being heat-off-cool dual switching, they didn't have compensating resistors - so these stats did have considerable hysteresis (as much as 3˚ depending on mechanical tolerances). When we started retrofitting electronic controls, I had the manufacturer add a lockout so the unit couldn't switch (say) to cooling mode too soon after it had been in heating mode.
Just for good measure, many radiator systems oscillate - with the TRV opening wide, the rad getting hot, the room overheating, the TRV (eventually) fully closing, the room cooling off, rinse and repeat. In part, it's because so many system never get balanced - with people wrongly believing that it's not required with TRVs.
I'm rapidly losing all tolerance for your false allegations.
Don't blame me for your lack of comprehension.
Please explain how the k-value of a material changes when you put it in contact with pipes containing hot water instead of pipes containing hot wire.
I did not say it does. What I did say is that it's but one factor or many - and the physics with a wet system is significantly different to an electric system. An electric system is a constant power input, a wet system is nominally a constant temperature input and heat input will reduce with reduces delta-T between water circuit and slab. Electric systems are generally installed to not heat a large slab - for the OP it will (I assume) be laid on insulation and the laminate laid on top, thus having a fairly low thermal mass. Wet systems are frequently laid in a slab, but with a significant surface are of pipe, and a fairly powerful heat source, heat up times aren't actually that long. But some wet systems are instaleld without a slab, so rapid heatup again, but not a significant thermal mass - more water than a slimline rad, probably something akin to the old fashioned cast iron segment rads that seem trendy these days.
Ignoring all the differences in typical installation arrangements, just the difference between heat inputs makes a significant difference to the heating curves.
And how many of those installations are of DIY-install electric heating mats in properties not designed with UFH in mind?
And that's relevant how ? Perhaps you could explain what is different for a property designed to be heating with UFH - other than aiming to be energy efficient just the same as a property designed to be heated by rads ?
I have not ever argued that UFH will be suitable for all situations, clearly there are many where it won't be.
Why? What do you expect it to do?
And your actual question is ? You just seem to be asking the same question for dramatic effect.
I've merely pointed out that you cannot be correct when you assert that "UFH doesn't work". I've witnessed it working in several properties, so either all those were figments of imagination, or you are wrong - I don't have that vivid an imagination. I've also pointed out that, like everything else, if it's not properly designed, installed, and configured then it may not work very well - which still doesn't support your view that "UFH doesn't work". Well is that a surprise ?
Still think they are selling a quality product?
Please state where I've passed comment either way on the quality of this particular product, and perhaps more appropriately, assuming that it actually does what the vendor says, why that is an issue as to whether it actually works or not ? Apart from issues like safety and reliability, please explain how a "poor quality" heating element will perform differently to a "good quality" element of the same general arrangement and power rating ?
If the element works, and
if the power rating is adequate for the requirements of the room, and if the thermostat works, then I'd expect it to be able to heat the room - the "if"s because I've not seen any figures, so no I don't know if it has the required capacity, and no I have not offered any opinion on this installation in that respect. Laminate is fairly low mass, electric is very fast acting (turn on and turn off at the speed of the relay), so I'd expect it to not suffer from huge lags and overshoots.
