Has any of you read my last post...
UPDATE - Ok after replacing the rose with choc blocks inside the hallway seem i have messed something up. The bedroom (bedroom3) i originally posted about now works
but when switch on turns the light on in bedroom1 (dim). This process also vice versa.
means.This process also vice versa
The Bathroom is working normally but hall doesn't come on unless bedroom is on.
Just to confirm I have not changed anything on bedroom 1 or bedroom 2, bedroom 3 is the room that this post is all about and the bathroom and hallway are what I put choc blocks in rather than the rose being inside the decorative fitting.
Luckily I pictured all of them (posted on here). I presumed all fitting in the centre terminals on a ceiling rose can all be put in the same choc, is this not the case?
If I was right thinking that then I may just have got something mixed up. I'll double check it tomorrow but all before and after pics are on this post if somebody can spot something. Wow thought I'd done well tidying up those connections: maybe not![]()
Then the answer is to learn how what you want to check with it works, to learn what needs to be checked for, to learn how a multimeter works and to learn how to use it to do the checks you want.I'll agree that those screwdrivers can be misleading in their results, but if you look at the so called instructions, they say nothing about how to actually use a multimeter in a diagnostic manner; all they're doing is explaining the points of the meter, and sticking meter probes in the wrong place can be even more dangerous than the screwdrivers.
Telling him to start trying different things without really knowing what's going on, hoping to get it working by luck, or by blindly following instructions to put-this-wire-in-that-hole without any idea as to why is irresponsible. He really should know what, and truly understand what, he is doing.
I didn't mark them just took pictures but looking at 'hallway' and 'hallway fix' and 'bathroom' 'bathroom fix' from what I can see it is wired up as was before just in choc blocks rather than ceiling rose, would you agree?
It is to show them how to do things.And just what the bloody hell is this forum about, if not doing exactly what you're saying he shouldn't be doing.
Does that make sense?We guide people along in fairly simple steps, then then expect their common sense to kick in when they get beyond their abilities. Sometimes it works, and sometimes it doesn't, but you can't have it both ways;
If you want to call it preaching that is up to you.are we here to help, or to preach.
OK, thanks. Can you take some good clear close-ups of all the cable joints at the ceiling positions so we can compare them with your previously posted pictures before you altered things?
Is the gym room the one with only 2 cables at the ceiling?
The last 3 digits of the jpg file numbers of the post pictures...
Can you write the room name against each?
728:
504:
420:
634:
451:
So we can compare with you previously posted "pre" pictures?
