Hi Can anyone help me or guide me a little.
I was after putting some oak beams and supports in as a feature in my extension. I don't really want pretend beams etc. I first looked at dried oak and was shocked how expensive it is, especially when you want a big fat beam of 3m and two uprights plus some other bits to go with it. So I did not want to pay out nearly a thousand pounds for that lot and thought my plans were doomed but then I looked on the net and came across stuff about building with green oak and I have started looking all over again at the possibility of doing what I want to do as green oak is a lot cheaper even if you buy the higher grade quality.
I have learnt that the green oak once put into a centrally heated house will slowly dry and shrink across its width and breadth but virtually not at all in length, which I found surprising. Of course it could also twist which would be a bit of a problem if it is pressed up against the ceiling.
So if this is the case it seems I could put a green oak beam across the ceiling and two uprights and not worry too much about them getting shorter, which is the most important measurement to worry about. Also if I am clever with some careful hidden wedges and maybe oak trim I could maybe adjust things as they changed.
I see several companies who do construction with green oak but I cannot find much on the net to learn more about building with it, ie I want to find some tips and pointers and what to watch out for etc, and maybe things to watch out for in the beams when buying them so not to get problems with twisting etc later on. The people that work with it must have learnt from somewhere. If I could get some basic knowledge I feel I could do a better job. after all I only want to put a few beams up not build a whole building like they do out of it. I do have some experience so I know about the dangers of the weight of it and securing it in place in the correct way etc.
I don't want the dark twisted oak you get in pubs but I want the light American very square look and I may do a couple of other things in the house with it if I am successful with the first project. I am very good with carpentry and have done many involved projects but I am self taught, I am not a carpenter by trade.
Any help or advice would be appreciated. Any links etc would help.
