I recently had an engineer fit a Hive smart thermostat to my Vaillant boiler. Previously the boiler was working with the standard Vaillant thermostat, and the radiators were providing the desired levels of heat.
Since the Hive has been installed, the boiler does not reach the target temperature flow for the radiators (set to 70degC), it will only hit about 52 degress. It also won't fire properly when it is in service/chimney sweep mode. It max's out at 52ish and then drops. The water heating seems fine.
Does anyone have an idea of what could be causing this? Is there anything I can do to fault find?
Thank you
Thank you
