I'm installing the VR65, VR10 and VRC470 and outside thermistor in place of Honeywell programmer and room stat.
Is it ok to run ebus signal in the existing 5core with the 230vac supply to the boiler or should I segregate into two separate cables and should cable to boiler be heat resisting type instead of PVC?
