- Joined
- 8 May 2017
- Messages
- 10,689
- Reaction score
- 2,887
- Country
Ok ,cheers. I wonder if on meddling with the zone valves may have introduced your new problem.
the way that your zone valves work, the small motor , when a demand is made opens the valve, once the valve is fully open it makes a small micro switch, this switch tells the boiler to fire up, sounds like one of the switches is stuck in the demand position (very common) the valve closes but the boiler doesnt know that the valve has closed hence why it keeps coming on, but the heat cant get out so just runs through the by-pass, it is an easy enough fix once you identify which valve actuator head is causing it@terryplumb - the boiler is going on short-cycle when there is no CH and HW demand. Ian's asked for a photo of the boiler display when it comes back on and short cycles. This is what i was referring to in my previous message.
yes you are best to replace the head , do you have a multi-meter and are you comfortable with electrics ?@terryplumb - yes it is very likely i have introduced this while putting the actuator head back on the valve.
@ianmcd - i have a feeling that this may be the HW motorised valve causing this. how do i go about fixing this? Do i have to replace the motorised head?
How did you remove the wires ? I know that you have posted a pic of both actuators removed from the valves, that wont make any difference whatsoeveri have gone all out and completely disconnected the valve head from the electric circuit.
Which are Ian ? They all appear to be connected together in the same earth terminal block .NEVER rely on colours in heating wiring, what you are calling "ground" will be earth here , but the colour means absolutly nothing, looking at your pics some green/yellow wires are being used as lives
