THE CODE S.33 (NOT F.33) IS A STATUS CODE, WHICH YOU ACCESS BY PRESSING THE i BUTTON. THIS TELLS YOU WHERE THE BOILER IS IN ITS SEQUENCE OF OPERATION. S.33 MEANS IT IS TRYING TO PROVE THE FLUE INTEGRITY (COURTESY OF THE AIR PRESSURE SWITCH) BUT DUE TO IT BEING A SQUARE BLACK ONE, IT IS PRONE TO STICKING FAULTS. I HAVE CHANGED HUNDREDS OF THE LITTLE BLIGHTERS. YOU WILL FIND SOMETIMES BY GIVING THE BOILER A LITTLE TAP AT THE BACK TOP RIGHT ,YOU CAN PERSUADE IT TO SWITCH OVER AND IT WILL FIRE. OTHERWISE REPLACE THE AIR PRESSURE SWITCH THEY ARE QUITE CHEAP AND VERY EASY TO DO PROVIDED THERE IS AT LEAST 6 INCHES CLEARANCE ABOVE THE BOILER
