    Dismiss Notice
Valiant Boiler Central Heating Burner Constantly On
Discussion in 'Plumbing and Central Heating' started by Columba, 5 Oct 2019.
  1. Columba
    Columba
    5 Oct 2019
    3
    Thanks Received:
    Country:
    Hi I have a Valiant Combi (Home) 35 Boiler that is just over 2 and a half years old. We had an issue earlier in the week where the boiler was causing the rcd to cut the power, which stopped after a few hours. Presuming heavy rain may have got in the flue and caused condensation which dried up. Anyway since then the central heating symbol is constantly flashing with the boiler making noises as if it’s burning. However both of the thermostats ESI ESRTP4’s are set to off and I can’t work out why without manually turning the central heating off on the boiler. Not sure if has reset its settings or there’s a fault, thought I would check here before calling an engineer if it’s something simple?
  2. Chris_W
    Chris_W
    26 Sep 2019
    2,687
    Thanks Received:
    745
    North
    Country:
    Are the radiators heating up? Is there a pre-heat turned on?
  3. Columba
    Columba
    5 Oct 2019
    3
    Thanks Received:
    Country:
    Hi Novice, when’s the thermostats are off and the central heating light is on flashing the radiators are off and cool. But if I turn the heating on the thermostat they come on okay and heat up. Eco mode is on however have tried it off and still have the same issue...
  4. picasso
    picasso
    8 Apr 2008
    9,769
    Thanks Received:
    2,346
    Essex
    Country:
    Do you have zone valves fitted to your heating system ?
  5. dilalio
    dilalio
    20 Mar 2009
    6,415
    Thanks Received:
    907
    Potters Bar
    Country:
    Altogether now... "T'is the season to fix zone valves" :sneaky:
    • Like Like x 2
  6. Columba
    Columba
    5 Oct 2019
    3
    Thanks Received:
    Country:
    Not sure what this is what am I looking for?
  7. DIYnot Local
    3 Sep 2019
    Country:
  8. Sponsored Links
Loading...
Share This Page
