I have been having an issue with my valiant boiler which is approx. 4 years old. Last week I got the F.73 fault (water pressure sensor) but the manometer read 1.5 bar and the EV seemed to be correct pressure. I read on these forums that sometimes cleaning the pressure sensor would cure this. I removed and cleaned the sensor and all seemed fine.
However, two days later I had the same F.73 fault again so I tried cleaning the sensor again. This time it didn’t work (I think the first time may have been coincidence). I also found that when I pressed the ‘-‘ button I had no pressure reading at all, the screen just displayed ‘–bar’.
I thought that the sensor could be U/S and ordered a replacement. However, I just fitted it and still get the same error. When I press the reset button (flame with cross) the fault light goes off for a few seconds and I hear something turning, but I’m assuming that the pressure fault stops any further operation.
I just wondered, is there something I can check when I get the ‘-bar’ reading on the display. Have I missed something when refilling the system with water?
Any information would be appreciated before I call out an engineer. Thanks in advance.
