Who are CORGI.?Corgi do not exclude dfe's Jeff in their information about multi-appliance ventilation
They sell vans.
Probably but their handbooks are used on gas training coursesWho are CORGI.?
They sell vans.
That will depend on how many outside walls there are...usually a semi detached will have 2 outside walls front and back , if an extension has been added then possibly only one outside wall to consider...was for 2 vents should they be positioned at opposite ends of the room or at a distance between the fires? Or same wall
Riley26 im not taking the p!ss it may help, just a bit of fun to get you thinking , if you have two fires are 8kw in the same room, how much advantageous air do you take into consideration when calculating ventilation ? ( I've helped you a bit there ) .also remember the advantageous air is to be considered . some homework for you , how much advantageous air do you consider for the fires in your room ??
a bit of revision for you
Thanks just let me look through my bookRiley26 im not taking the p!ss it may help, just a bit of fun to get you thinking , if you have two fires are 8kw in the same room, how much advantageous air do you take into consideration when calculating ventilation ? ( I've helped you a bit there ) .
before you worry about vent position , you need to know the free area vent size for ventilation for open flued appliances
