DFE - Decorative Fuel Effect or Decorative Flame Effect Fire
These are normally either tapered shape or basket type fires designed to fit in the builders opening; the tapered version fits the shaped chairbrick, the basket fits a plain opening. They are very low efficiency since excess air can't be controlled. Their KW input can vary from 5Kw to over 30Kw
ILFE - Insert Live Fuel Effect or Insert Living Flame Effect or Inset Live Fuel.....etc
The fire sits within the builders opening and is sealed to the surround at the perimeter. Normally either screwed back or pulled back with wire. As they are sealed the excess airflow is controlled through the fire and are more efficent. They are normally designed to increase convection currents through the fire box. Kw power is often 7 to 15KW
OLFE - Outset Living Flame Effect..etc
Again sealed to the surround so more efficent than plain DFE's but the firebox sits in front of the surround. And due to limited excess air and enhanced convection current efficienties are higher.
Generally all DFE's must have 100 cm2 ventillation unless the MI's say they are 7Kw or less and require no vent. These fires are often designated reduced draught. Obviously any spillage/extractors etc and ventillation must be increased accordingly.
Most ILFE/OLFE are 7 KW and the MI's state no extra ventillation required, above this ventillation required.
Older fires (especially DFE/baskets) often have no data plates and are in poor condition. Gas rating often shows vast quantities of gas are consumed (over 30KW sometimes) and often with no ventillation. If you encounter any fire with no data plate disconnect it and follow IUSP since you have no way of verifiying its safety.
Be careful of fires installed in living/dining rooms with the rooms knocked through - different ventillation requirements apply. If you leave a fire operating I suggest you issue an NCS form advising a CO alarm is fitted (or put it on your invoice) ie do everything you can to cover yourself. ASD's, ODP's do not work as we now know.
I disconnect at least 90% of fires (some brand new installations from local fireplace companies). You won't be popular but your conscience is clear. Often telling the landlord/homeowner it will cost a fortune to service/locate manuals/phoning technical etc will immediately provide a Yes to allow capping off
