I did. I forgot that was the context of the most recent exchanges Does that mean that if the existing socket was turned into a blank plate, with joints behind it feeding athe socket in a slightly different position,you would not say that an 'RCD upgrade' was required?You posted that the OP could leave existing sockets and spur off them (Addition)......
However, as I implied, if you feel that adding an additional socket triggers the need for an RCD upgrade, then I would expect you to think that adding a new circuit (with new OPD in CU) triggers the need for a 'CU upgrade'. Is that the case?
