wall crumbled behind socket backbox
22 Jul 2008
Yorkshire
Hi everyone. I have recently moved into a new (to me) house. I was replacing a damaged socket front and noticed the backbox was loose. It was nailed in place and not really soundly fixed as there was a large void( 1 inch or so) deep. So although my query isnt strictly electrical, i thought it may a be a good palce to get an answer to my question " What should i fill the void with to enable me to fix it securely?". I was thinking polyfiller, but i also have some plaster and cement knocking around. Is expanding foam suitable? Any advice would be gratefully received.
You don't say what the wall is constructed of. ie Brick, thermal block, lath & plaster, plasterboard etc.,
I assume from your comments that it is a solid wall, If so, I find the quickest (as you don't have to wait for anything to set) and easiest way is to get rid of the loose material untill you reach something sound. Screw a a piece of timber to that and then screw the backbox to the timber.
appologies, it is a brick wall faced with thick plaster. That sounds like a very simple plan...the best ones usually are, much better than hanging around waiting for plaster to dry. Thanks
I've used no-more-nails type stuff when I was in a hurry before now.
Depends if there's lots in the site container at the time  8)
OR use some old bonding plaster, that will go off in 5 mins :S
I used some "sticks like sh1t" before - I stuck some of that in the hole, pressed the backbox in, and put a screw through the back of it.
Thermalite walls - cant beat em. :lol:
