Hi
I am nearly ready to install my wall plate for the roof trusses which have been ordered. The truss manufacturer has been out and measured so hopefully everything is going to be correct there.
I asked the following question to the truss manufacturer (okay
might be a stupid question).
Q. As my extension cavity is wider than the original house cavity, do I still lay the timber wall plate to the same height as the existing?
Their answer.
A. I can confirm that we would have allowed for the cavity being wider in the extension, and taken the wallplates as being the same height on the new as on the existing.
My questions.
What tolerance do I have? I'm confident i'll get the wall plate level and within a few mm of the existing height, or does the height need to be bang on?
Should the wall plate be laid on 10mm mortar just like the bricks/blocks?
I will need to strap the wall plate although it's to celcon lightweight blocks; is fastening these restraint straps into the blocks with standard wall plugs going to be good enough or should I use something else?
Sorry if these are basic questions! I'm a serial worrier!
Cheers, Chris
Their answer.
My questions.
Cheers, Chris
