    Dismiss Notice
Wall to partition garage conversion?
Discussion in 'Building' started by rickypj, 20 Jun 2019.
  1. rickypj
    rickypj
    29 Nov 2013
    6
    Thanks Received:
    West Midlands
    Country:
    Hi All, Im looking to enlarge my kitchen by knocking through and using part of my garage, whilst partitioning the remaining front of the garage off to use as a bike/tool store and leaving the original garage door in place. I have done a lot of research on raising the garage floor to bring it up to the kitchen level so am happy with this. What I am struggling with is the spec of the wall I need to build to partition the garage. The garage is integral to the house, has a bedroom above and the exterior garage wall is a cavity wall so this should not need any extra insulation. Would a single wall of thermalite blocks be suitable to construct the partition wall from? The section of the garage that will remain a garage is partly made up of a single skin of brick and protrudes from the front of the house so I imagine the new wall will in theory need to be built as if it were an exterior wall?
    If anybody has had any experience with this and could offer some advice that would be great.
    Please see attached picture for some detail.
  2. ^woody^
    ^woody^
    3 Sep 2006
    26,065
    Thanks Received:
    3,201
    West Mids
    Country:
    Thermalite? No.
    Timber stud, 100mm celotex between, and 25mm across the internal face. 12.5 plasterboard and skim both sides.
    If that house was built in the past 30 years or so, check planning permission for conditions preventing garage conversions without permission.
  3. Bluepeppo
    Bluepeppo
    21 May 2019
    14
    Thanks Received:
    2
    Country:
    As Woody suggests there may be some restrictions for converting the garage into a habitable space. These restrictions can also be private covenants attached to the deeds and nothing to do with planning permission. Sometimes it's just a matter of paying a fee to the company that built the house or buying an indemnity policy if the company is no longer trading. That said, if it still looks like a garage.......:sneaky:
    • Thanks Thanks x 1
  4. John D v2.0
    John D v2.0
    26 Aug 2016
    5,609
    Thanks Received:
    750
    Country:
    You might need to double board the garage side for fire resistance, also make sure the new floor is insulated if you haven't already.
    For the fire resistance If there's still a partial garage they consider you might store a motorbike full of petrol and require accordingly.
    The council building inspector would hopefully be helpful
  5. A_Novice
    A_Novice
    29 Dec 2017
    178
    Thanks Received:
    2
    Country:
    We have been required to do this. Left side being the garage.
Loading...
Share This Page
