    Dismiss Notice
Waste disposal switch ??
Discussion in 'Electrics UK' started by djhope, 9 Mar 2010.
  1. djhope
    djhope
    21 Mar 2008
    18
    Thanks Received:
    Worcestershire
    Country:
    I need to fit a switch on the wall to opperate a waste disposal machine.
    What type of switch can I use. I don't need anything fancy just a plain white switch or toggle. I've got a 13a fused socket installed under the sink. An air switch is too expensive.
    Thanks for your help
    David
  2. Sponsored Links
  3. EdwardCurrent
    EdwardCurrent
    29 Apr 2007
    907
    Thanks Received:
    22
    Country:
    Hello.
    What do you mean by a 13A fused socket please ? A single outlet would be 13A ? Or do you have a 'fused' spur under the sink already ??
    What type of switch does the manual say the appliance needs ?
    The more info you post the easier it is for others to help you.
    Regards
    Ed.
  4. RF Lighting
    RF Lighting
    31 Mar 2006
    19,986
    Thanks Received:
    1,351
    Leeds
    Country:
  5. electronicsuk
    electronicsuk
    7 May 2007
    3,316
    Thanks Received:
    275
    Lincolnshire
    Country:
    Sounds as if you may be going about this backwards. The normal thing to do would be to wire a 13A switched FCU or 20A DP switch straight onto the ring final (or spurred from it), with a 13A socket on the load terminals.
    You can go from 13A plugtop (suitable fused) > flex > switch > waste disposal if you want, but it's a bit of a DIY lashup and not really the ideal solution.
    Also, although air switches may be expensive, the price is worthwhile if it will avoid operating a switch directly when you're very likely to have wet hands.
  6. Johnmelad502
    Johnmelad502
    23 Aug 2008
    2,923
    Thanks Received:
    52
    Cumbria
    Country:
  7. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,099
    Thanks Received:
    2,065
    Oxfordshire
    Country:
  8. electronicsuk
    electronicsuk
    7 May 2007
    3,316
    Thanks Received:
    275
    Lincolnshire
    Country:
    Except that the price of the air switches on the site linked to by John are little more than what it would cost to assemble a grid with suitably marked switch and buy all the necessary parts for the job.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
