You can probably find it on iPlayer shortly. Tonight's episode covered an 'electrician' named Derek who was doing Part P work without being registered. I was slightly dubious about their description of what work is notifiable, particularly that stating that fitting an outside light required notification to the council.
The first job they had the guy do was fitting a double socket in the kitchen. He removed an existing fused spur and replaced it with a double socket. He made a complete balls up of removing the tiles (and glued the broken shards back to the wall with what looked like window putty). Oh, and didn't bother to screw the box to the wall.
Perhaps the best bit was when the guy was replacing a fuse box with a consumer unit. As the light was fading he simply pulled the lid off the service cut-out and jammed the feed to the downstairs lighting circuit into the feed from the street with his screwdriver.
Excusing the typical BBC Watchdog hype it was pretty shocking to watch.
