It's a door. What the OP does with the room enclosed is of no concern to the fitter the requirement is for the the installation to keep out water.
You can't say "Well, its a bathroom and will get wet anyway, so the window I'm fitting can leak like a sieve"![]()
I can recommend the stick on weatherstrips, although a bit messy to fit they work well, my drive slopes down to the garage:
If course he is.The door fitter has done what he was contracted to do - fitted a working door. I do think £3000 was a bit OTT for a door, but the OP isn't complaining about that
So, you fitted that?
What door was there before and did it have the same problem?Hey guys,
Do you think this is acceptable? Newly fitted garage door, and the first time it rained I noticed water coming in under the door:
Following morning I was left with this:
Emailed the manufacturer/fitter (same company), to say I didn't think the door was closing properly (pushing the seal into the floor enough) and to ask if was there anything that could be done to adjust it.
Response was as follows:
"Sometimes this can happen with some doors, even though the seal is tight to the floor, there is still the chance of water coming through. This is something that unfortunately cannot be foreseen prior to the installation.
Weather strips are purchasable from us for £120+VAT, alternatively they are available to purchase for self-fitting from companies such as Screwfix."
The door/fitting cost was north of £3k. Is the above a valid response and I just need to suck up the costs, or should I am I being reasonable to expect a weather-proof door?
Andy
Yes. It's only the small area between acco drain and doors and a slight slope - water used to come in and now it doesn't.
The rubber seal is designed to keep out dust, leaves etc and help the door shed water. It’s not designed to stop water coming into the garage. If it did, then any pooled water it was keeping out would just run into the garage when you opened the door.Thanks for all the comments folks, looks like I’ve sparked a debate.
In answer to the question, this is a new double garage in an extension, so this isn’t a replacement like for like. However the old door was a crappy 70s up and over jobbie and didn’t have issues like this - albeit the garage concrete may have been laid differently.
The new door has a massive rubber seal on the bottom of it, so why bother fitting that if it’s ‘not supposed’ to keep water out.
Harry, I don’t know what beers your on today but talking about plasterers, carpet fitters and roofers are just bizarre and extreme analogies.
Personally I don’t think I, as the consumer, should need to specify that I don’t want puddles forming in my garage when placing an order for a new garage door…it’s implicit that the door should form a barrier to the outside elements.
LOL.The rubber seal is simply there to allow for discrepancies in the floor level,
only to keep drafts out .....
deflectors down the side rather than seals
In my opinion, the door supplier should have quoted for and supplied a raised threshold to stop runoff running under the door. You would have paid more for it, but they’d have fitted it at the same time as the door so wouldn’t have cost any more in labour. I’d be going back to the door company and offering to pay for the threshold if they come back and fit it for free.
