Evening all,
Had a company come out today to run in a new MDPE supply pipe to replace my existing lead. I was intending to do this myself but just didn't have the time to do it.
I had applied for permission for this work from my water supplier (Yorkshire Water) and under their lead replacement scheme if I do my side they confirm their side is lead free. They said the pipe needed to be laid and terminated at the property end and then left for connection by them.
I explained this to the new company but wasn't on site due to being at work so my wife was in. I had looked at various documentation regarding the standards when I was going to do it myself but am not sure of what is a requirement and what is just best practice, as a result I have several concerns:
View media item 101257View media item 101256
Can anyone with experience in these things advise please, I was planning on getting advice from the water board tomorrow before they come asking for the invoice to be paid but I would appreciate any insight.
Thank you very much in advance
- They have laid, connected, and backfilled without any inspection by Yorkshire water.
- I was under the impression that the minimum depth was 750mm including where the pipe enters the property, theirs enters practically at ground level, only about 30cm below the air brick under the floor which I know is at almost ground level.
- The pipe is not lagged where is passes in the floor void space.
- The pipe is punched directly through the foundation, not in a duct.
- No proper stopcock appears to have been fitted on the MDPE, it goes down to 22mm copper then a 22mm to 15mm push fit elbow with a normal inline 15mm isolating valve like you would have on sink taps.
