    Dismiss Notice
WB1A persistent F4 error - repair or replace?
Discussion in 'Plumbing and Central Heating' started by MikeAustin, 11 Mar 2018.
Thread Status:
Not open for further replies.
  1. MikeAustin
    MikeAustin
    26 Mar 2009
    186
    Thanks Received:
    6
    Bristol
    Country:
    I am having problems with my Viessmann Vitodens 100 WB1A 18kW Heat Only Gas Boiler (Serial no.7179920501169106). It was fitted in October 2005.
    There was a repeated F4 error in April 2016, which was fixed by the removal of the problematic 'flappy valve'. It was serviced on November 2017, and the matrix burner and fire proof blocks each end of the combustion chamber were replaced (badly crumbled!)
    There have been no problems until about three weeks ago when the F4 error came back. The condensate syphon was cleaned, the electrode block and the ignition module were replaced and it was OK for a couple of weeks.
    Now the F4 error has started again. Today, despite several resets, it will not restart at all.
    I guess it is the control panel, which is only available on back order for £283+VAT. Or is there anything else to check?
    A 12 years old boiler - is it worth repairing, or should I replace it?
  2. Hason
    Hason
    3 Apr 2015
    140
    Thanks Received:
    14
    Bournemouth
    Country:
    This site does not support DIY gas and posts giving advice on gas work, or encouraging or suggesting it, may be deleted. However, posts are not routinely monitored, so no work should be done as a result of seeing anything on the site.
    Read more:
    https://www.diynot.com/diy/threads/diy-gas.8090/#ixzz59ljB9XyA
  3. Hason
    Hason
    3 Apr 2015
    140
    Thanks Received:
    14
    Bournemouth
    Country:
    Read more:
  4. MikeAustin
    MikeAustin
    26 Mar 2009
    186
    Thanks Received:
    6
    Bristol
    Country:
    Read more:
  5. Sponsored Links
  6. MikeAustin
    MikeAustin
    26 Mar 2009
    186
    Thanks Received:
    6
    Bristol
    Country:
    Read more:
  7. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Thread Status:
Share This Page
