WC Pan to Soil Pipe
18 Feb 2006
Cardiff
Currently re-fitting the bathroom. The wc is being sited in the same position but the as the outlet from the pan is higher than the original, the connection to the soil pipe is causing a problem.
The outlet and soil pipe are both standard 10cm. The distant between pan and soil pipe is approx 50 cm. The fall between outlet and soil pipe is approx. 8 cms so it's not possible to use a straight piece of pipe.
Anybody have a solution? Are there things like flexi soil pipes on the market. If not what are my options?
Thanks in advance
You can get Multiquick fittings from merchants that have offsets and extension pieces , i suggest you take your measurements to the local plumbing merchants , cheers
