As with a lot of things BRegs-wise, it's a sledgehammer to crack a nut and largely superfluous in many instances - exposed areas subject to driven rain would be an exception. But, regardless of its efficacy or even its necessity, the reason for its inclusion is as per Nose's comments.
"In case your wall plate at roof level allows the ingress of water into the cavity. In normal circumstances the weep vents don't actually do anything."
Have you ever seen any sarking boarding being witty or jocular? Roofing felt made out of green soft and fuzzy stuff? BAT straps flying around in the evening and leaving half-eaten butterflies on the bedroom floor?
weep vents are designed to work during heavy and prolonged periods of wind driven rain. it would be hard to discriminate between ejected water and rain droplets.
regardless of all your windy bluff joe, the purpose of weep vents is clear.
Have you ever seen any weeping? [/quote
Have you never been on site during heavy rain while construction is in progress !! can assure you it aint air that comes out of them. Surely the name gives it away "weep holes" or should they be called " cavity vents" maybe we should rename air bricks and call them weep bricks.
