What a strange thing to write.What's so special about you, and what you've ever heard of?
Have you never asked a question on the forum because you did not know something?
NO.Is no one allowed to ask questions here any more?
Yes I have used these too and like them but the annoying thing about them is that after fitting it is raised off the plasterboard about the thickness of a washer so if you were fixing a block of wood for example it is only (sort of ) held on the face of the plasterboard at the washer area.I have used the Timco zip-fit toggles to fit shelving on plasterboard walls. They are rated up to 30kg on single skinned plasterboard, 47kg on 25mm double skinned PB.
I used them after the Interset fittings started to fail, to be fair, I hadn't realised that the walls were double skinned and my Interset fittings were designed for 12.5mm.
Of course, any of us would do that, but ....Maybe they might ask what it is and/or how the name originated.
Of course they are - and you did. However, maybe I misunderstood, but you appeared to not just be asking how the word originated but seemed to be being 'critical' about the name (not intuitively obvious) that had been given to the product (e.g. your mention of "Hoover".Is no one allowed to ask questions here any more?
Maybe they might ask what it is and/or how the name originated.. Is no one allowed to ask questions here any more?
The above questions appear to be essentially the same. I've just responded to the first, so that response also applies to the second!What a strange thing to write. Have you never asked a question on the forum because you did not know something?
What is the fuss about then and why did no one actually answer the question?Of course, any of us would do that, but ....
Please explain how and why you drew that conclusion.Of course they are - and you did. However, maybe I misunderstood, but you appeared to not just be asking how the word originated but seemed to be being 'critical' about the name (not intuitively obvious) that had been given to the product (e.g. your mention of "Hoover".
Presumably because, just like the case with you, no-one who read the question knows the answer.What is the fuss about then and why did no one actually answer the question?
Partially because of the general 'tone' of the discussion but, more specifically ...although I personally feel that it is a 'fact of life/language' which is not worth fussing about, I can understand your frequently being critical about the (far from unique) fact that many people use the manufacturer/brand name ("Hoover") of one of the first such product to refer to vacuum cleaner of any brand. Hence, by saying that the present word was "half-way" to being like "Hoover", you appearedto be being at least "half-critical"Please explain how and why you drew that conclusion.
It has never been even remotely 'obvious' to me. Only the author of that statement could answer your question.To remind everyone: ..... Why is it obvious?
Toggles are my favourite as they are a secure clamp and don't usually need too much depth behind.
Intersets are good but I've found them to be less reliable than toggles and there is no way of knowing what has happened behind the board, it is essential exactly the right size is used for the thickness and for that matter exactly the right size hole too.
I've known the 'fingers' snap, also twisted round as the screw is tightened which chewed away at the rear of the PB, (hopefully only when fitted incorrectly?).
One contractor we used had no idea there is a proper tool and he set them using a cordless drill making a right mess into the bargain.
These are good too but require a bigger hole and more depth behind (and expensive)https://www.toolfixservices.com/Pro...vy-Duty-Plasterboard-Fixings-Toggler/TOG25030
I shall therefore take that as vindication.Presumably because, just like the case with you, no-one who read the question knows the answer.
That was only because of the snotty reply to my very reasonable question.Partially because of the general 'tone' of the discussion
Yet no one knows the reason for calling them intersets.but, more specifically ...although I personally feel that it is a 'fact of life/language' which is not worth fussing about, I can understand your frequently being critical about the (far from unique) fact that many people use the manufacturer/brand name ("Hoover") of one of the first such product to refer to vacuum cleaner of any brand. Hence, by saying that the present word was "half-way" to being like "Hoover", you appearedto be being at least "half-critical"
There you go, then.It has never been even remotely 'obvious' to me.
Yet he chose not to.Only the author of that statement could answer your question.
What a strange name for a hollow wall anchor; however did that come about?
" I'm out "<lots of things>
So when I can I use a forstner bit to cut away that washer thickness from the back of the wood so that the whole surface is in contact with the plasterboard.
Or if the fixture is metal then I use the forstner to remove a washer thickness of plaster. I know you shouldn’t break the paper but think the outcome of the whole surface being in contact with the rest of the plasterboard is ultimately stronger.
The section the fingers are touching is the bit I am talking about. It doesn’t look much here but does stick out.
Yes I miss - wrote it slightly as you are right the plasterboard has a skim and the idea was to make the recess only as deep as the plaster skim and not break the paper --- but I have done. !Good point.
I normally work in houses that have plaster over the boards, and yes I have recessed the collar in the past as required.
