- Joined
- 21 Jan 2017
- Messages
- 94
- Reaction score
- 1
- Country
Hi, Guys would like your advice and opinions please concerning my wetroom renovations.
I have stripped the walls back to bare brick and removed the previous concrete screed. Sadly, the previous screen was done by someone who didn't slope it correctly allowing water to flow out of the wetroom into the next room under the door.
- I would like your advice please on what kind of boards (Waterproof boards) to use, please?
- The brick walls are quite out, so I am in two minds whether to Dot and dab (Manipulate the board till level) and then support that with aqua panel screws into the brick wall or timber stud the wall (pack it) levelled, then screw the aqua board on there? What is your opinion on this, please?
- The third question is, should I set up my concrete bench before or after creating the slope screed? I was thinking maybe after? because I could then factor the height of tile and adhesive into the height of the bench, though I could also do that before I slope screed. I just need to factor the highest point of the screed. Assumably this would also be easier as laying the concrete blocks on a flat levelled floor would be easier right. That way all I have to do is slope to the bench. Your thoughts on this, please.
