Hi all,
Bit of a long story, but we have just refurbished a house and ended up using higher than normal desks in our study which has meant that a plug socket now has no clearance above the desk (cut in assuming standard desk height). Initially, the socket was installed upside down but felt it didn't look right (I also read that there can be issues if it's upside down), so we ended up turning it to normal orientation. The issue now is that we can only use certain plugs in the socket which have a lead coming out of the top, side or front but not from the bottom.
Is it worth leaving it as it is or should it be moved up? We have another socket that is only about 4 cm above another desk. Is this ok?
See attached photos for reference.
Cheers,
Will
Cheers,
Will
