I have been asked to look at a couple of walls which have heavy staining and some paint pealing.
There are run marks coming from above the lead.
The painter has had a specialist from the paint manufacture come out to look at it and they have come to the decision that the moisture in the coping stones is running over the lead and the lead is staining the wall.
I'm not so sure,
I was wondering if the salts etc in the coping stones are bleeding out.
The stones are around 15 years old and are very porous. They hold a lot of water.
When you look closely at the sand/cement that the stones are set on, you can also see some slight staining.
The coping stones were treated last summer with a moisture repellant, but this hasn’t worked.
The coping stones are so wet that you can scratch the surface with screwdriver without much pressure as they are very soft.
I have been asked to remove the coping stones, remove the lead and replace with a rubber or bitumen membrane then reset the coping stones.
I wonder whether it’s worth replacing the coping stones at the same time.
I'm not so sure,
