    Dismiss Notice
What kind of screw for rawlplug uno?
Discussion in 'Tools and Materials' started by phloaw, 4 Nov 2019.
  1. phloaw
    phloaw
    19 Jun 2019
    25
    Thanks Received:
    Country:
    I have this kind of anchors (plugs): rawlplug uno https://www.rawlplug.co.uk/product/uno-universal-plug/
    The sizes of screw it accepts are clear; however, there is a lot more to screws besides sizes.
    Despite googling hard, I couldn't understand what type of screws they should go with: wood screws? sheet metal screws? machine screws? coarse thread? fine thread?
    Every source seems to only specify the diameter and length of the screw to use with a particular size of the plug, nothing else!
    Also, if there is any other feature of a screw relevant to their coupling with a given anchor, I'd be interested to hear about that.
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    20,266
    Thanks Received:
    3,947
    Northumberland
    Country:
    Plastic plugs work with any coarse threaded screw, that is, almost anything apart from a machine screw.
    Therefore you can use wood screws or self tapping screws which has a thread all along its length.
    John :)
    • Thanks Thanks x 1
  4. phloaw
    phloaw
    19 Jun 2019
    25
    Thanks Received:
    Country:
    Sounds easy, then. Thanks!
  5. Burnerman
    Burnerman
    7 Feb 2008
    20,266
    Thanks Received:
    3,947
    Northumberland
    Country:
    No problem - the Rawlplug universals look like good kit, although I've never used them....Its Fischer stuff for me, the plastic spline is brilliant for anchoring the plug.
    John :)
  6. Sponsored Links
  7. opps
    opps
    16 Jun 2006
    3,906
    Thanks Received:
    569
    London
    Country:
    My favourite nylon plugs were the Tox ones which seem to predate the Fisher "universal" plugs. The Uno ones have become my go to standard fixings since Tox gave up on the UK market years ago.
    My problem with the Fisher ones (assuming that we are talking about the same ones) is that the plug has no collar and can occasionally spin as you insert the screw. The Tox equivalent was sold with and without a collar.
    With regards to cavities, thanks to advice on this site I now use interset fixings.
    • Thanks Thanks x 1
  8. Burnerman
    Burnerman
    7 Feb 2008
    20,266
    Thanks Received:
    3,947
    Northumberland
    Country:
    • Thanks Thanks x 1
  9. opps
    opps
    16 Jun 2006
    3,906
    Thanks Received:
    569
    London
    Country:
    Those are very similar to the Tox plugs, i.e. when used in cavities the plug splays outwards as it pulls itself up the thread of the screw.
    I might get some of those. I have previously used the Fisher UX plugs but found that sometimes the screw would sneak out of the side of the fitting.
    • Thanks Thanks x 1
  10. Burnerman
    Burnerman
    7 Feb 2008
    20,266
    Thanks Received:
    3,947
    Northumberland
    Country:
    Agreed, I found the UX series a bit on the soft side.
    John :)
    • Thanks Thanks x 1
Loading...
Share This Page
