- Joined
- 10 Apr 2021
- Messages
- 34
- Reaction score
- 4
- Country
hey guys, i'm installing some bathroom wall panels and the recommendation is to screw them to the walls as well as using adhesive.
my wall in this case is tiled, behind which is plaster and then brick.
would i be correct in thinking i need to use some countersunk masonry screws? i'm relatively inexperienced in diy so just want to double check beforehand, my thinking being masonry as that will be hardest material i will encounter, and countersunk as they will go in the tongue/groove bit and it needs to be flat as possible.
thank you
thank you
