Where can I get an 'undercut saw' to cut into architraves
14 Jun 2004
Surrey
Them used to be called dowel saws. (So you can cut a dowel off flush with a surface.) The job is OK with a flexible panel saw, and I've seen it done with a biscuit jointer.
Driven all over the flipping place today and nobodys even heard of this 'undertcut saw'. 'dowl thingy-dingy' or a 'whatsitthatgoesroundawidget'
I saw in a store a 19 squid angle grinder !!!
Could I not use an angle grinder to cut into skirting boards and door frames
no you couldnt! Can use a biscuit cutter. The saw you are after is called a pull saw or a dowel saw. They definetly sell them in homebase about 14 quid, theyre styled on japanese pull saws
Thermo
as i said i found them on google, called as you said they are
