Where can I get comfortable knee pad trousers?
11 Oct 2016
Hi, I kneel down a lot for work and am looking for some comfortable knee pad trousers.
I got some from Screwfix but they aren’t very comfy, the knee pads are too low and the pants tend to fall down leading to a bit builders bum.
Can anyone recommend some comfortable ones please?
I wear loop braces. Just at work. They hook on belt loops so no clips as they come off. I prefer X braces type but you can get Y type depending on trousers loop position at back.
You need to keep them up and knee pads in correct position.
I have loads hanging from trousers and they don't budge. No problem with knee pads.
If you don't like that Idea you need to tighten belt. I can't do that. Lad at work has belt so tight his face goes red but would never wear braces.
Mine are provided FOC from my employer. We use Travis Perkins, who use RokWear - no complaints from me.
I get mine from aldi. Not the thin £9.99 ones, but the thick £15-£20 ones that come out every now and again. They are thick comfortable and have the Cordura reinforcement patches.
Importantly, the knee pockets are bottom fed, so the pads don't creep out the top. Look for this above all, or perhaps side fed.
Comfort is subjective, as will be whether your waist holds them up! But try an elasticated belt from Snickers or similar.
I have the same problem i can never get trousers to fit me properly.....probably because im so fit and ripped :p
But scruffs are the best I can get.
