I have one of those wristbands you mentioned. It's quite good for small screws/nuts etc
Many years ago someone gave me a small plastic box with a spring loaded lid which was on a wristband. You push down to drop your screw/washer, nut etc and the lid sprang up to trap them inside. Bit of a bitch to get the right one out without tipping them all on to a table first but the idea behind it was good.
I think you can get a screwdriver with two small grippers on the end. You push the driver on to the screw end and the grippers retract into a tube and act like a chuck by gripping the screw head. As you start to drive the screw home the tube eventually hits the wood/wall and slides up the screwdriver shaft allowing the grippers to open and release the screw.
Not sure if these are any good.
https://www.amazon.co.uk/Draper-275...+gripping+screwdrivers.&qid=1586454582&sr=8-5
