I'll bet you he doesn't have it moved in the end.
Andy
Andy
Jeez what a knob
You sir, are a model tenant - respect is due.[quote="richard7761";p="2326316 You have to comprehend I'm under direction, under conditions! If you cannot get that you cannot grasp my situation.
I .
C'mon richard lighten up mate. Your post was ok, but you didn't seem to be listening to anyone. your post also went on and on when in reality the job your talking about is a very straight forward simple job that you DONT need to be gas safe registered to do.
I .![]()
******************** Why can`t you take what I said @ face valueYou sir, are a model tenant - respect is due.[quote="richard7761";p="2326316 You have to comprehend I'm under direction, under conditions! If you cannot get that you cannot grasp my situation.
I .![]()
Why do you quote what I said? What is wrong with you? Are you an idiot or what?
The conditions are what the council have told me. The whole post was trying to figure what tradesmen might fit in with these conditions. What is wrong with that? Nothing. So, what are some people getting their knickers in a twist for? Nothing.
Some trashy person says something negative, not in jest, and all the weak-minded, easily-led, low-life makes it's appearance.
I am a gas safe registered engineer. You do not have to have a gas safe registered engineer to move a radiator. You do need a gas safe registered engineer to work on anything that will involve gas, or the correct functioning of a gas boiler, such as moving a flue or changing a gas-related component inside the boiler. Moving a radiator does not involve any gas or the correct functioning of the gas parts of the boiler.
Just get on with moving the rad yourself and don't tell the council. If you don't know how to move a rad connected to a combi boiler, I would charge £70 (plus any extra pipework) if you were within reasonable distance of where I live. £50 for the labour plus £20 for Corrosion Inhibitor, plus extra if any more pipework was needed. I go into a lot of council properties servicing boilers and if you saw some of them you would not be asking the question. Some of them make me want to take off all my clothes and throw them away as soon as I am out of the front door. The council will not be interested in your radiator, unless you cause a ceiling to collapse by not doing it properly.
