Hi, first post here so please bear with me! I am going to block up an internal doorway with a stud wall. The door is out, and the frame has been removed. I can see a lintel, so thats a good start! My question is relating to the width of the CLS timber I need. The doorway is brick width (100mm), plus a bit of render and 2mm plaster coat and I plan to use sound proof plasterboard at 12.5mm thick. So if I use 63 mm wide CLS timber and screw two sheets of plasterboard to it I end up with a new width of 88mm. Which is way below the original brick width. If I use 90mm wide timber and add two sheets of plasterboard (25mm) I end up at 105 mm which is proud of the brick! I will get the whole room plastered, but what is the best way to go about this ? Thanks in advance
