Hi, I have purchased an off the shelf French door 2090mm x 1190mm to be fit in place of a window which is around 2000mm wide with the top of the window being around 2200 above the DPC. The house is a mid 70’s build standard cavity wall construction.
I want to fit the doors tight to a finished edge rather than centrally in the window opening, bricking up on just one side.
i have read that a window lintel is not suitable for French doors and that the window lintel should be removed and an RSJ installed. Is this so? It seems strange as the window surely requires no more support than the French doors.
As a bit of background I laboured on building sites when I was younger and I have some limited bricklaying experience. I’ve build garden walls, retaining walls, internal stud walls, hung and fit doors, general DIY etc so hopefully this isn’t beyond my skill level? Your help and advice much appreciated thank you.
