Willis Heating System
My controller (iboost+) is designed to be used if required with two immersion heaters, and will auto heat the top one first, until the thermostat turns it off, then it will start heating the bottom one. 1772383633930.png If one compares this to the Willis, the Willis is far cheaper. The iboost+ is nearly £300, that's without the cost of two immersion heaters. And for me a new tank which can take two immersion heaters or one of these 1772384235067.pngat £150 each. So the Willis system is cheaper it would seem?
Since I already have the iboost+ then the dual element would seem a good idea, but back to the whole idea, is it worth it. At the moment I use a single 27" immersion heater, summer 1772384620514.png at 8.5p/kWh so £3 a month, so just not worth worrying about.
My controller (iboost+) is designed to be used if required with two immersion heaters, and will auto heat the top one first, until the thermostat turns it off, then it will start heating the bottom one. ... If one compares this to the Willis, the Willis is far cheaper. The iboost+ is nearly £300, that's without the cost of two immersion heaters. And for me a new tank which can take two immersion heaters or one of these ... <> ... at £150 each. So the Willis system is cheaper it would seem? Since I already have the iboost+ then the dual element would seem a good idea ...
I think is is all a bit tangential to a discussion about the (traditional) use of a Willis heater, but ....
.... if your aim were to heat all the water in the cylinder (which is the usual concept of a 'stored hot water' system) then I don't think that the ("iboost+ switched") dual-immersion system would offer any advantage. As far as I can see, a 'high internal immersion' or external Willis heater only offers an advantage (over a 'low internal immersion') if one primarily only wants to heat a bit of water at the top of the cylinder (since those approaches minimise mixing with the colder water below. If you want to heat the entire contents of a cylinder, it's all got to be heated, so you might just as well have just a 'low' (or 'long') internal immersion.
The idea was to use solar, rather than give it away for free, the first 20 months I was tied into British Gas, who would not pay me for export, as they said I had filled in their form in the wrong format, and wanted £75 if I was to leave early.
On moving to Octopus found the problem was a missing MPAN number which was sorted within two weeks. Be it in a battery, or as hot water, unless a solar panel system has some sort of storage it will be unlikely to pay for its self within a reasonable time. But the iboost+ and other controllers were really made for when export was not measured but assumed, the old FIT system, and it allows a variable amount of energy to be stored in the water. Today is not really worthwhile, like the optimiser, with fluorescent lights, things have moved on, and today often considered as snake oil.
The idea was to use solar, rather than give it away for free, the first 20 months I was tied into British Gas, who would not pay me for export ...
Yes, I realise that (which is why I suggested that your comment was somewhat 'tangential' to our discussion).
However, the amount of spare energy you have available from solar is the amount of spare energy you have from solar - so, if your intent were (after the solar has all been used up) to heat the rest of the water in the cylinder in some other way, then I don't think there would be any advantage in having the 'dual immersion' system you mentioned - you might just as well use the solar supply for just a single bottom/long immersion. I think that it would only be if you intended to heat just a little bit of water at the top of the cylinder that initially using a high internal (or external Willis) heater would offer a little advantage.
I don't understand. The post of mine you're initially quoting is mainly about the disadvantages (inconveniences) of any system which heats small volumes of water 'as needed', whereas the "this" of mine you go on to quote offers one suggestion why it might be that one tiny pair of countries of the world have made widespread use of the system, hence presumably not as concerned about the 'inconveniences' as most of the rest of us.
I am certainly saying that changing from my present system (reliant on stored hot water) to one in which I heated only small amounts of water 'as needed' would be a 'disadvantage (inconvenience) but I do agree that it would probably 'make no noticeable difference' whether the latter were achieved with an external immersion (Willis) or a conventional 'internal' one.
You mean in terms of the eventual need to replace the immersion? If so, I suppose that's theoretically correct, but I wouldn't want to endure years of ('inconveniently') having to anticipate and act upon my every single need for a bit of hot water in order to avoid potential problems in replacing the immersion a number of years down the road!
As I've recently written, in an ideal world, storing hot water is non-ideal - so, in that sense, I would agree with you -so 'instant heating' is theoretically preferable (and, in the UK at present, ideally 'instant gas' because of the large price difference of the two fuels) - but the crucial point (in relation to 'convenience') is that it must be 'instant' (not 'anticipating need and then waiting a few minutes').
However, if you want to do it "instant", 3kW electric heaters (whether internal or 'Willis') are not going to be adequate - you'll really need something like the 10.5 kW of half-decent electric showers for reasonable performance.
Sorry but in your last few posts I've really lost track of what you are saying so I think a boing time
Since I have now almost got my thoughts clear, I think that "what I am (now) saying" can be summarised pretty briefly and succinctly:
1... Having to anticipate every single need for hot water, react accordingly and then wait (a potentially significant amount of time) for the hot water to become available is really not very 'convenient' or compatible with many of our life styles.
1a... if, nevertheless, one is prepared to accept that inconvenience, then very much the same can be achieved with either a 'top' internal immersion or an external Willis heater. The Willis system would probably be slightly more efficient and, in the very long-term, easier to replace, but there is really unlikely to be much noticeable difference. In practice, I don't think there'd even be a lot of difference even if it were a 'bottom' (or 'long') internal immersion, since the newly-heated water would only have to make one 'journey' up through the colder water above it.
1b... my one (probably now only) outstanding 'technical uncertainty' about the Willis system is that I still do not really understand how it can result in significant heating of water below the level of the Willis heater (including your example with the heater actually above the cylinder). If I'm right in my suspicion that it can't do that, then the situation is the same as with a 'high' internal immersion - that, since the position of the heating element is 'fixed', so is the maximum amount of water that can be heated by it.
1c... if one has a pretty large ('standard size') DHW cylinder, it seems a little odd,if not 'perverse', to only use perhaps 25% of it to provide 'on-demand' hot water, with the consequential 'inconveniences'.​
2... If one doesn't want the 'inconvenience' of having to 'plan' and then wait for water to be heated by a relatively small (3kW) source, that leaves us with with either stored hot water or truly 'instantly'- ('real-time') heated hot water. Storage of hot water is theoretically not ideal (due to some inevitable losses, hence some 'wastage' (of energy and money) but instantly-heated water is unlikely to be satisfactory (in terms of both temp and flow) unless one has a heat source of 10 kW or so (or~20 kW [or 2 x 10 kW] if one wants to be able to satisfactorily use a hot tap and shower simultaneously)​
1... Having to anticipate every single need for hot water, react accordingly and then wait (a potentially significant amount of time) for the hot water to become available is really not very 'convenient' or compatible with many of our life styles.​
Possibly not but the way it used to be and I truly don't recall significant problems
1a... if, nevertheless, one is prepared to accept that inconvenience, then very much the same can be achieved with either a 'top' internal immersion or an external Willis heater. The Willis system would probably be slightly more efficient and, in the very long-term, easier to replace, but there is really unlikely to be much noticeable difference. In practice, I don't think there'd even be a lot of difference even if it were a 'bottom' (or 'long') internal immersion, since the newly-heated water would only have to make one 'journey' up through the colder water above it.​
Which it does very well, particularly a long vertical
1b... my one (probably now only) outstanding 'technical uncertainty' about the Willis system is that I still do not really understand how it can result in significant heating of water below the level of the Willis heater (including your example with the heater actually above the cylinder). If I'm right in my suspicion that it can't do that, then the situation is the same as with a 'high' internal immersion - that, since the position of the heating element is 'fixed', so is the maximum amount of water that can be heated by it.​
Think of the restricted Willis vessel causing it to work like a pump
Which one will have with a short top heater but not with a Willis
Many other countries have 2 phase 40-50A instant heaters which seem to cover a whole house OK
Unless it is per-point instant heating, or you live alone, then instant heating is not preferable in theory or practice. Otherwise you have the "excitement" of the shower running cold when someone uses a hot tap, or hot when they use a cold tap.
I'm glad you said "half decent" there. Note that typically a combi will be around 30kW regardless of the minimum heating demand for the property. For our rental flat, around 2kW to keep it toasty in winter, while (AFAIK) no 30kW boiler will modulate down to that.
As to the Willis arrangement, as I see it there's little between that and an in-tank immersion - except for marginally quicker recovery times under certain circumstances. That it's popular in some places I would put down to local custom - a lot of installers will stick with what they are familiar with, and as they are common, then installers will be familiar with them, and so they remain popular just by familiarity. In other places, different things will be popular.
It's likely that they will have become popular back in the days when there was a culture of "putting on the hot water" in advance of needing it, and only when a need was planned - and in that scenario, the "top down" heat up would be an advantage (if not needing a whole tankful). I think many of us will be old enough to remember when that was a common approach to managing hot water.
These days I'd suggest there is little benefit in instant heating anyway. With heat pumps, they cannot provide the output to run a shower - so storage required. If you are using solar (thermal or PV), again, storage required for maximum benefit. If you want to take advantage of variable tariffs, again storage required for maximum benefit. And as pointed out, modern spray foam lagged cylinders will (if the pipework is also similarly lagged) have fairly low standing losses - which also aren't "lost heat" for most of the year where the cylinder is inside the property (which is the case for most houses) so it just replaces a small part of the heating output.
I said I wouldn't, but...
Your theory is very wrong, as has been explained to you multiple times. The Willis will thermo-syphon the water very effectively, drawing in cold at the bottom, hot out the top, and storing the hot, at the top of the main cylinder. Cold is drawn in at the bottom of the Willis cylinder, rises as it picks up temperature, then flows out of the top.
Indeed, but not here (UK) or I believe Ireland. As I mentioned above, customs vary significant between countries - and even between different areas within a country. Reasons will be numerous - the availability of "high power" mains supplies will be one of those. In the UK, it's only relatively recent that 60A, 80A, or even 100A supplies have become commonplace - hence the idea of having 20+kW (I'm assuming the 2 phase mentioned is something like a 480V split phase) would have been unimaginable here until quite recently.
In some countries, it's still common to pay different standing charges based on supply capacity - enforced by a supplier owned/provided MCB which I believe can be well below what we might consider practical (switch on kettle while microwave running = power goes off sort of impractical.)
We've had many a 'nostalgic' discussion, but I would say that long gone are the days when people in UK (and many other places) were happy to wait for kettles or buckets of water to 'boil up' before they could do the washing or washing up (let alone 'take baths') and with showers being almost unknwn.
As I said, if one is happy with 'on demand' heating of smallish amounts of water 'as needed' (hence the anticipation and 'waiting' involved) then I really don't think there is much to choose (in terms of 'performance') between an internal immersion and an external Willis heater.
Think of the restricted Willis vessel causing it to work like a pump ... Which one will have with a short top heater but not with a Willis
As I presume you understand, that's where I still have uncertainties - see below.
What do you mean by "2-phase 40-50A instant heaters"? If you are talking about a total of around 18-22 kW, that might well be reasonably 'adequate', but is more than the total available supply for many UK domestic installations, and an amount of supply that I'm not at all sure exists in "many other countries".
As for my continuing 'uncertainties', as I have said I'm as yet far from clear as to what would happen after one reached this situation (with the 'pink' water all up to more-or-less the 'target temp') ...
As I've said before, I presume that a lot depends upon where the stat is and what is its 'setting'. If there is a stat in the Willis heater which switches the heater off when the water in it is up to 'target temp', then I presume that nothing further would happen once the above situation had been achieved.
If there is no such stat in the Willis, then 'what happens next' presumably depends upon where the stat is and what is its setting. If the Willis heater remains powered after the temp in the Willis is 'up to temp' then a small amount of slow 'pumping' might happen, since he temp of water in the Willis would rise to slightly above the temp in the vertical pipe rising from it - so that a little 'rising of warmer water' would presumably occur, but the temp of water in he Willis could end up very high.
However, I still don't see the situation as materially different from that of a 'high up' immersion in the cylinder, in which case I would not expect there to be appreciable heating of water below the level of the immersion (or Willis).
I've already made the point that the 'excitements' you mention are a risk if one has less than around 20 kW or so of instant water-heating power available. However, that doesn't alter the fact that there will be some 'wastage' of energy and money, at least during Summer months, if one uses 'stored hot water'.
Glad you agree - that's what I've been saying all along.
Someone, maybe you, made this point earlier, and I'm sure that it will be at least partially correct. However, if (as some people have suggested) it really were the case that the Willis system offers "obvious very clear advantages", I would have expected it to have become far more widely utilised (globally) over the decades since the system was first descsribed.
Indeed - but, as I've just written, most of the world seems to have 'moved on' from those historic/nostalgic days!
Agreed - and, again, that is the crux of the point I've been trying to make!
In fact, as I've been saying, the Willis system is a bit 'worse' than 'instant' water heating, since it's a "wait a while" (rather than 'instant') system :-)
... Your theory is very wrong, as has been explained to you multiple times. The Willis will thermo-syphon the water very effectively, drawing in cold at the bottom, hot out the top, and storing the hot, at the top of the main cylinder. Cold is drawn in at the bottom of the Willis cylinder, rises as it picks up temperature, then flows out of the top.
It's not a 'theory' of mine - rather, it's something I don't yet fully understand. See what I've recently written.
Do you accept, that a heating radiator on one wall, will cause the air to rise above it, makes it way across the ceiling, then fall down the far wall - the traditional theory of how a radiator in a room behaves?
