Willis Heating System
John - you seem to be forgetting the fact that other people have very different needs to yourself.
I must say I would have thought that my household was very 'typical' as regards 'needs' for hot water, but that's not really relevant.
I am not a salesman, attempting to sell you a Willis system, I am simply pointing out the differences to what you have, and potential advantages. With that, I will leave the thread, as it is becoming simply repetitive.
You surely must realise that my interest is not in relation to my own use but, rather, an academic/intellectual interest in trying to understand the workings of this system, and to understand why a system which was invented a long time ago, and which has some 'champions' (who believe that it offers 'clear advantages'), has been taken up by such a minute proportion of the world's population.
However, you may be pleased to know that, although it is nothing to do with the technicalities of the system (i.e. 'how/why it works and behaves), I think that I may have accidentally 'seen the light' as regards this discussion, in realising that there is some serious 'chalk and cheese' involved. It didn't 'sink in' at the time, but, on reflection, what I wrote in a recent post (coupled with a link that EFLI recently posted) has made me suddenly 'see this light'.
Throughout this discussion, I have been thinking as someone who has bought into the concept of using 'stored hot water' and therefore rarely, if ever, has a need for 'newly heated water'. However, the link recently posted by EFLI reminds me what this is all about, when it says:
Typical use time: > Shower: 10 minutes, > Dish Washing: 5 minutes, > Hair Washing: 5 minutes ....
So, for a shower (typical requirement – 35 litres @ 40°C), the Economiser will heat only the top 35 litres of the cylinder in about 10 minutes, and the unit should then be switched off.
For maximum efficiency, we recommend that the Economiser be fitted in conjunction with a timer (such as the ELEMEX T1). This will ensure that the heater is switched off after the required time. You can then set it and forget it.
So, this system is being aimed at people who have totally abandoned the concept of using stored hot water but, rather, want to heat up (from cold) just the amount of water they need for each task (be it a shower, washing up, hair washing, simple hand washing or whatever). That requires them to anticipate their need to undertake each of the tasks by setting a timer for the requisite heating time (or trying to remember when to switch it off) and then waiting that amount of time before they can undertake the task. I could do essentially the same with immersions (albeit, as you have pointed out, slightly less efficiently/quickly, because of a little mixing of heated water with cold) but there is absolutely no way that I would want such tedium and disruption in my life.
I would therefore suggest that anyone contemplating a Willis system should instead seriously consider perhaosspending their money on some decent insulation for their DHW cylinder. They would then (like I do) always have essentially unlimited amounts of immediately available hot water, immediately enough for anything (including a bath, should they choose to take one) without any hassle or need to anticipate how much hot water they would next need, and when - and if their primary/only water heating were by electricity, then they might also be able reduce costs by taking advantage of tariffs with 'off-peak' periods.
Basically, horses, for courses!
I suppose that's one way of putting it!
[ as an 'aside of detail', to start with ..... Regarding ....​
So, for a shower (typical requirement – 35 litres @ 40°C), the Economiser will heat only the top 35 litres of the cylinder in about 10 minutes ...
... assuming that Physics and Maths are the same in Ireland as elsewhere, by my calculation to heat 35 L of water from, say, 18°C to 40°C would require about 898 Wh, about18 minutes (not 10) with a 3 kW heater and, in practice, the cold supply could well be a fair bit lower than 18°C, so it could take a fair bit more than that. ]​
Having now realised what we're talking about, in some senses, the Willis idea ('abandoning the concept of stored hot water') seems to be a bit of a joke since, at least in terms of 'time', it's no different from or better than real-time instantaneous water heating ....
Working with my figures, if one's cold water is at 18°C and one wants/needs 35 L at 40°C, then (ignoring 'losses') a 100% efficient 3kW heater is going to take about 18 minutes to achieve that, no matter what the 'heating arrangement'. One can either do that in the conventional 'instantaneous heating' fashion, by watching the heated water 'trickle out' painfully slowly for18 minutes, or one can twiddle one's thumbs for 18 minutes whilst waiting for a Willis heater to heat the water and transfer it (with some 'losses') into a cylinder for temporary storage prior to use. Either way, it will be 18 minutes from 'switch-on' to when one's desired amount of heated water has become available. I suppose some people might be happy with that'wait', but I certainly don't see it as an advantage over traditional stored hot water.
In fact, what w're talking about reminds me of my grandparents' hours in my early years. During summer (coa fire with back boiler not in use) when they wanted hot water for washing, washing up or whatever, they had to wait whilst it heated up in a kettle or galvanised bucket on the gas stove!
[Serious question!] Is there perhaps something about the attitudes to life, personalities (perhaps more 'laid back'?) or lifestyles of the Irish which makes them more prepared to sit around waiting for hot water to be created?
What an insultingly ignorance-filled read "The Universe According To JohnW2" would be
Goodness :-) Anticipating, and in an attempt, to pre-empt, knee-jerk reactions like yours, I even prefaced my comment with "[Serious Question]", but seemingly to no avail :-)
I have absolutely no 'negative', let alone "insulting or ignorance-filled", thoughts about Irish people - and would have had a problem if I did, since I've been married to one for over 50 years!
However, there undeniably are cultural differences between different groups, whether defined by geography, ethnicity, religion or whatever, and I was wondering if that might explain the situation we appear to have seen with the Willis system.
As I wrote, from the user's point of view, the main difference between the Willis system and (almost ubiquitous in UK) 'conventional alternatives' ('stored hot water', or true 'instantaneous heating, as, for example, with combis and electric showers) is that the user has to anticipate the need for hot water and then wait (for potentially quite significant periods of time) for it to be created. Many, maybe most, would probably regard that as 'inconvenient', hence undesirable.
The Willis system was 'invented' decades ago, and has apparently been widely deployed in the island of Ireland, particularly Northern Ireland, but seems to have been little used anywhere else in the world. Given that global communication has been pretty good for many decades, one imagines that a substantial proportion of plumbers etc. throughout the world must have become aware of the system but have nevertheless not seen a reason to significantly adopt to.
There is therefore a need to understand why something which some believe "offers clear advantages" has only been widely used in a geographical area which contains less than 0.1% of the world's population. The most likely explanation I have so far thought of is that of some sort of cultural difference which has resulted in a very different attitude to what most people in the world would probably regard as an 'undesirable inconvenience' which they would prefer not to have to live with.
I'm sure there must be other possible explanations and look forward to hearing of any suggestions.
My personal view remains that, at least in 'developed' countries, the only 'sensible' approaches to domestic hot water are to either have 'stored hot' water (with very well-insulated cylinder, and ideally gas-heated, at least in UK) or to have true 'instantaneous' heating, as in combis and electric showers etc., - although some people (including some here) would say that even the latter is usually 'not very sensible'.
Goodness me, my initial knee jerk reaction to Robins post was somewhat negative however this later reply is a bit of a shock.
What are the disadvantages to the Willis system? We have ploughed through 200+ posts, essentially discussing the differences between Willis heating and 'in vessel' heating, we have learnt some advantages of both over the other described but I see very little to indicate that either create a significant difference and certainly nothing to cause a situation such as:
If I had reason to make a definitive choice between the 2 electric heating systems I think I'd find it very difficult to make a choice however as I've said so many times external heater(s) to the storage vessel is a common system in large installations where I'm sure the better option will be selected.
I can think of only one undesirable inconvenience when comparing 'internal' Vs 'external' heaters systems and that is the undesirable inconvenience of replacing an 'internal' immersion heater every few years. Changing a 'Willis' heater is a vastly simpler job.
Especially if it's been installed by a plumber as they insist on using some sort of glue and then the next plumber frequently tears the flimsy copper. Changing a 'Willis' vessel is a vastly simpler job.
So if you have seen the light, now let me add solar into the mix. When using solar PV to heat DHW we have a sensor
so a current transformer monitors when we are exporting and how much, and the immersion heater is only activated when otherwise we would be exporting, and also only to a rate which will not cause an import, so the 3 kW unit may be working at only 200 watts.
We know the Willis will heat the top of the cylinder first, but when the immersion is not giving out a full 3 kW, will that top bit be warm enough? The whole idea is DHW is 60°C or more due to legionnaires, and the water at between 20-60°C is kept to a minimum, in winter I can't stop the CH from also heating the DHW, so regular the whole tank is hot. In summer, so the tank is regularly heated to over 60°C I have it set to use off-peak to also heat the water.
Without the off-peak, would the water get hot enough with the Willis system? If I am only putting ¼ a kWh into the domestic hot water, will it give me hot water at the taps, or increase the likelihood of legionnaires? Once I see
I know the DHW is safe, and seeing
or
I know it is working, but with a Willis does
really mean the tank is hot, or does it just mean the Willis unit has turned off, and the tank could still be cold?
As I wrote, I was expecting 'knee jerks', and did what I could to 'pre-empt' them, but without much success :-)
What are the disadvantages to the Willis system? We have ploughed through 200+ posts, essentially discussing the differences between Willis heating and 'in vessel' heating, we have learnt some advantages of both over the other described but I see very little to indicate that either create a significant difference and certainly nothing to cause a situation such as: ...
Virtually everything I have thought and written in this very long thread has been about the 'technicalities' of the Willis system (i.e. how/why it works) (which is why I started this thread) and, thanks to some of the more useful input I've had here (including from yourself) I have now got my head a fair bit around that - although, as you probably realise, I still have 'uncertainties' about some aspects.
However, what has only just sunk in to my head is the fact that almost all the arguments being thrown at me, leading to assertions that the Willis system 'offered clear advantages', are based on the assumption that one has little/no stored hot water, so that the 'starting point' for everything people have been saying to me has been one in which all the water in the system (cylinder, pipework and Willis heater, if present) was 'cold'.
I now understand, and have conceded, that IF one has little/no stored hot water, then the Willis system offers some (small) advantages because even with a very high immersion, there is still a little mixing of heated water with cold, as the heated water 'rises up' to the top of the cylinder - something which doesn't happen with Willis. Also, if the Willis heater has been 'on' fairly recently, there may be a very small amount of 'stored hot water' in it available (within the external heater and pipework) for 'immediate use - but even that will presumably get diluted by (mixed with) cold water from the cylinder (probably at least 50:50).
However, moving to your question "What are the disadvantages of the Willis system?", the disadvantages (or, rather, per below, 'the lack of appreciable advantages') I've been talking about are nothing specifically to do with the Willis system but, rather, are (I would say fairly major) disadvantages of any system which did not have decent amounts of stored hot water. If you look, I think (hope) you'll find that I have rarely, if ever, talked about "disadvantages of Willis system" but, rather, have said why I don't see any appreciable advantages (other than those small ones mentioned in the previous paragraph - i.e. IF one is trying to use a system which has little/no stored heated water then the Willis system is 'almost as bad' as doing the same thing with a high immersion.
As above, IFI had abandoned the concept of having decent volumes of stored hot water, then so would I - because I don't think that the small advantages of the Willis system (as above) are significant enough to be an issue. The important point is that I would not be considering any system (whether using an internal or external/Willis immersion) that did not provide with with decent volumes of stored hot water.
It's really much the same as the choice between a shower fed with stored hot water and an electric shower or shower fed by a 'combi' - I think that many/most people would agree that, when possible, the former is preferable.
I can think of only one undesirable inconvenience when comparing 'internal' Vs 'external' heaters systems and that is the undesirable inconvenience of replacing an 'internal' immersion heater every few years. Changing a 'Willis' heater is a vastly simpler job. ... Especially if it's been installed by a plumber as they insist on using some sort of glue and then the next plumber frequently tears the flimsy copper. Changing a 'Willis' vessel is a vastly simpler job.
Unfortunately (personal experience :-) ), I have to agree with that, but I doubt that many people think that far ahead when choosing what system to install!
So if you have seen the light, now let me add solar into the mix. ...
As you may now realise, the light I have seen does not relate directly to the Willis system but, rather, to any system (whether the heating is internal or external to the DHW cylinder) that does not involve heating and storing a cylinder full of hot water.
Is there another possible advantage to keeping a whole cylinder of water topped up for ready use in some conditions too?
At harsh times of the year when the temperature falls and we might think of frost protection to our pipework, a little background heat on our pipework , dependant upon the routes that pipeworks take, might just elevate that temperature enough to deter a total freeze up of system parts in a household without a gas boiler and maybe/maybe not jut a couple of gas fires throughout the whole property.
Where I live there are a heck of a lot of sandstone terrace houses built around 1900 both with and without external kitchens which were built before ridges and freezers were common place (neither was electrics in the homes originally) and such kitchens were a "natural" cool damp place for safe food storage in those days (compartively speaking) , the cold water supply often came in via the kitchen area then up and over to other rooms if needed , any cylinder was often not far from this supply in terms of pipework length and a cylinder heated by a "coal fire" back boiler and later with an immersion heater too, hed upwards by a little bit of background heting to some rooms and some pipework..
These days you`d never plan this little possible advantage but for many years it might have been a possible advantage, no bathrooms back then, no inside loo, it was in the back yard away from the house or the bottom of the bak street or every few streets, "Toilets inside houses was a dirty disgusting concept!" and some houses actually had a bath plumbed in a bedroom if at all or many had a tin bath that was often placed near the coal fire and Sunday was usually "Bath Day" for the household and in larger households the bathwater was often shared in order of ages, would you belive it these days? LOL
This tends to make me think otherwise:
I think you are still saying the Willis system would be a disadvantage in your situation, it would not, it would make no noticable difference to the way you opperate. However from your experience of maintenance it would offer advantages.
Having lived with gravity and pumped stored HW, combi, multipoint geyser and instant electric; of the 5 variants my personal preference solidly remains with instant electric. That could very well change if my showers changed from the sub 2 minutes they are to the 20-40 minutes I've seen quoted by others on the forum:unsure: :)
I've read your post several times and deliberately delayed reply.
At harsh times of the year when the temperature falls and we might think of frost protection to our pipework, a little background heat on our pipework , dependant upon the routes that pipeworks take, might just elevate that temperature enough to deter a total freeze up of system parts ....
Yes, I suppose that is one possible advantage of having stored hot water, but it's a potential issue that may have to be addressed for some pipework even if one does have stored hot water!
As I've written before, I think we might agree that "if everything else is equal" the concept of stored hot water is not an ideal one - since, no matter how well lagged the cylinder, there are bound to be some 'losses' (of heat), hence 'wastes' of energy and money - but that, in practice, having stored hot water is usually the theoretically preferable approach. There are, of course, some situations in which it is impractical/'impossible', most commonly when there is a lack of space to accomodate a reasonable sized DHW cylinder.
However, if one has installed "a reasonably-sized DHW cylinder", then it seems a little perverse to actually abandon the concept of maintaining a tank full of hot water (such that some is always available for immediate use) and, instead, to just heat the amount of hot water needed for each and every task (be that by an -in-clinder immersion or external Willis heater), with all the inconvenience/hassle that introduces?
[As for "avoiding pipes freezing up", although I have stored hot water, I have in the past had problems with my (multiple zone) CH pipework in dusty corners of my large house that are in 'zones' which are rarely heated. I have therefore implement a system which occasionally activates all of the zones, ocassionally for a brief period (e.g. for 5 mins every 2 hours) ... ]
I don't understand. The post of mine you're initially quoting is mainly about the disadvantages (inconveniences) of any system which heats small volumes of water 'as needed', whereas the "this" of mine you go on to quote offers one suggestion why it might be that one tiny pair of countries of the world have made widespread use of the system, hence presumably not as concerned about the 'inconveniences' as most of the rest of us.
I am certainly saying that changing from my present system (reliant on stored hot water) to one in which I heated only small amounts of water 'as needed' would be a 'disadvantage (inconvenience) but I do agree that it would probably 'make no noticeable difference' whether the latter were achieved with an external immersion (Willis) or a conventional 'internal' one.
However from your experience of maintenance it would offer advantages. ...
You mean in terms of the eventual need to replace the immersion? If so, I suppose that's theoretically correct, but I wouldn't want to endure years of ('inconveniently') having to anticipate and act upon my every single need for a bit of hot water in order to avoid potential problems in replacing the immersion a number of years down the road!
As I've recently written, in an ideal world, storing hot water is non-ideal - so, in that sense, I would agree with you -so 'instant heating' is theoretically preferable (and, in the UK at present, ideally 'instant gas' because of the large price difference of the two fuels) - but the crucial point (in relation to 'convenience') is that it must be 'instant' (not 'anticipating need and then waiting a few minutes').
However, if you want to do it "instant", 3kW electric heaters (whether internal or 'Willis') are not going to be adequate - you'll really need something like the 10.5 kW of half-decent electric showers for reasonable performance.
