Windows updates on laptop
4 Jun 2009
London
Neighbour got a laptop that just keeps updating windows (running XP)
Now C drive full, laptop really slow and runs check disk every time he turns it on
Went to delete some updates from add/remove programs but not sure which ones to delete
Have turned automatic updates off at minute
Any advice on how to stop updating and also deleting updates from C drive
20 Jul 2007
Lancashire
Windows updates would not fill a hard drive, otherwise every computer would be overloaded. There must be something on the HD that has filled it.
Go to Computer and double click on the C: drive and open Program Files folder.
See what is listed that he does not use and then use either that programs uninstaller in the start menu or use Control panel > Programs to uninstall
30 Dec 2008
Bristol
Download a disk space analyser tool like zero assumption and see where the space has gone. As above unlikely to be updates but there might be some temp files saved somewhere (which uninstalling the update probably won't remove either). Might be time for a fresh install.
4 Jun 2009
London
Just booted it up and get blue screen saying fault in non-paged disk area and get screen saying windows did not close down properly please start from
last known good configuration
safe mode
command prompt
start normally
I select last known good configuation and get check disk then after finished loading get
microsoft.net framework box
An unhandled exception has occurred in your application. If you click continue the application will ignore this error and attempt to continue, if you click quit the application will be shut down immediately
'cannot control acermemusagecheckservice service on computer'
I go into add/remove programs in control panel and there are loads of
Windows installations eg
compatability pack for 2007 Office system has 6 installed on various dates from 18/02/11-02/07/11 all with KB and numbers after them
26 instances of .netframework ending in various numbers letters such as
CA
CLR
ASP.net
2
PreXP
Then 23 under
Microsoft Office Standard Edition 2003 ending in
KB OTKLOADR
MainSP3
etc
23 Windows IE 8 updates ending in KB then numbers
then (stopped counting at 60) Windows XP software updates including
updates for
Media Format
Media Player
XP
