Could someone help me out with this please.
I have bought a new electric cooker which has a power rating of 3870W. I have also purchased a new gas hob which has an electric ignitor. The hob has a flex already attached so I am assuming it only provides the power for the ignitor. The hob has some kW ratings on the nameplate but I am assuming that as these are quite high it is regarding the heating power of the gas rather than electric kW.
The oven can be wired with 2.5 T&E according to the manual which I am planning on connecting to the existing Cooker connection unit under the worktop. This is run in 6mm2 cable, do I need to change the 32A MCB to a 16A one in the consumer unit?
Also is it acceptable to run the ignitor flex to the cooker connection unit or should this be from it\\\'s own FCU?
Any help would be much appreciated.
