Wiring Novoguard 6 to Eurosec CP8L LCD
31 Mar 2016
Malta
Hi Experts,
Just bought a new alarm to replace my old one. the control panel is a Eurosec CP8L LCD and the external sounder is a Novagard 6.
Have a query about the wiring. Can any one help?
I have worked it out so but would like some confirmation or otherwise.
Panel ....... Sounder
Bat + ....... Internal battery +
Bat - ....... Internal battery -
Bell Hold ....... 0 v and TMPF
Bell + ....... +12 V
Bell - ....... S-
SABTMP ....... TMPR
Strobe- ....... STR-
but what about the Strobe - on the control panel does it need to be connected with the external sounder
and what are the FLT and SET + on the sounder for?
Hope that someone can help.
Ray
Do you mean strobe + ? If so not needed as its allready fed at the bell box pcb
Flt is a fault output ( only used on grade 3 systems )
Set + not required it can be used for bell squawk on some systems
Thanks a lot that has solved my problem.
Can I ask another question please? its regarding an internal detector PIR/MW (Active 8 AM) what is the anti-mask feature? How is this wired to the same Control panel (Eurosec CP8L LCD)?
thanks once again
Dear Sparkymarka,
Thanks for your reply. Its good to know that people with your evident expertise are there ready and willing to help.
regards
Ray
