    Dismiss Notice
worms in toilet....yuck!
Discussion in 'Plumbing and Central Heating' started by tilly10, 22 Aug 2011.
  1. tilly10
    tilly10
    18 May 2007
    70
    Thanks Received:
    Country:
    I have seen worms in the toilet pan several times over the past couple of years. I used to think they just crawled up the pipework...( is that possible ?)
    Now I'm beginning to wonder if there is a crack in the pipe underground and that where they are coming from.
    Or could it be birds dropping them over the stack.... is it a sort of breather pipe?
    Any ways.... I'm starting to get quite sick at the thought of worms in my loo.
    They are skinny reddish brown, and vary in size.
    We don't have a header tank in the loft, that was taken away years ago when central heating was fitted.
    And nooooo they aren't from us, having a couple of children, and dogs I know what parasitic worms look like lol
    Help.
    TIA Lynn
    Oh and are ARE alive *shudders*
  2. gas112
    gas112
    27 Oct 2009
    16,047
    Thanks Received:
    4,468
    Country:
    Change your diet time i think :LOL: :LOL:
    More than likely a leaking joint under ground
  3. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,047
    Thanks Received:
    1,068
    Norfolk
    Country:
    Soil pipe cracked is my guess as well. You could always take up fishing with all that readily available bait. :D
  4. JohnD
    JohnD
    15 Nov 2005
    56,524
    Thanks Received:
    2,878
    21st Century
    Country:
    Cook Islands
    red worms are common where a drain or sewer has cracked or broken. Usually they live in the wet ground, where you find them when you dig out to repair.
    If they are in your WC trap the crack is surely very close to the WC.
  5. tilly10
    tilly10
    18 May 2007
    70
    Thanks Received:
    Country:
    Thanks guys. OH POO!!!Actually! I should have known it would be a cracked pipe under ground.... we built a conservatory a few years ago, and the foundations are over the soil pipe. Although we did bridge it with paving slabs- I guess the weight got to it.
    Oh and the loo is on the first floor so those pesky worms sure do travel lol
    Thanks again
    Lynn
  6. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    No chance. :rolleyes:
    If we're talking garden worms, someones playing around.
    A photo of worms please.
  7. plumberdan
    plumberdan
    22 Aug 2011
    52
    Thanks Received:
    3
    Yorkshire
    Country:
    Your main problem here is not the worms in your toilet, if it is a cracked drain near the house, then there will be waste water leaking out which could potentially compromise the foundations of the building, I would recommend a drain inspector to locate exactly where the damage is and go from there, a look at a program called help my house is falling down may enlighten you as to what could happen if left alone!
  8. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    Worms don't climb 3m up a vertical soil pipe. :LOL:
    In which case I think the cracked soil pipe theory can be ignored.
  9. JohnD
    JohnD
    15 Nov 2005
    56,524
    Thanks Received:
    2,878
    21st Century
    Country:
    Cook Islands
    Perhaps the worms were given a helping hand.
  10. tilly10
    tilly10
    18 May 2007
    70
    Thanks Received:
    Country:
    Oh no children here... both grown up and left. We do have grandkids, but they are babies and the worms appeared in the middle of the night... grandkids are miles away in their own homes.
    Now I'm getting really worried :(
  11. tilly10
    tilly10
    18 May 2007
    70
    Thanks Received:
    Country:
    OK could they be coming down the soil stack... stink pipe my ole dad used to call it ;lol
  12. tilly10
    tilly10
    18 May 2007
    70
    Thanks Received:
    Country:
    Next time they arrive I'll take a pic... good job my loo is always spotless eh lol]
  13. JohnD
    JohnD
    15 Nov 2005
    56,524
    Thanks Received:
    2,878
    21st Century
    Country:
    Cook Islands
    have a look in the cistern too.
    could water from the gutters be getting into the soil pipe? it should be quite separate. these worms must be coming from somewhere damp, and not very clean.
    Are there any unused drains or capped-off pipes going to the soil stack?
  14. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    Not unless you have a birds nest at the top and some damn clever worms.
  15. Big Tone
    Big Tone
    6 Jun 2009
    1,502
    Thanks Received:
    8
    Birmingham
    Country:
    If you leave a Richard the 3rd in there I can give you some tips on your diet. Too much iron or beetroot, not enough fibre etc. [​IMG]
    So a man goes down to the doctor and takes a black turd from his pocket to hand it over to the doctor and asks, "this can't be good Doc, is there something wrong with me?" :D
Loading...
Share This Page
