First time poster, I'm staying in a place that has Worscester 35CDi and the hot water has stopped working.
The boiler fails to turn on with the hot water tap. It seems to work fine, as in I can turn on the heating for the radiators, it just seems to be a switch not engaging with the hot water tap.
It happened once before but a plumber was called out when I was not here so I'm unsure as to the remedy.
As it seems like a flaky switch of sorts I was hoping someone here may be able to put me right, the literature I've found on line has been no help, and what I've found on this forum suggests a PCB fault, given it was recently fixed with the same problem by a call out plumber I'm guessing it's something simple. -And hoping.
Thanks for any help,
Dave Short.
Dave Short.
