Okay interesting one here.
Bungalow property, roof contains horse hair insulation and ceilings are made of asbestos tiles!!!
Already you're think ******!!
Tuesday, pipe burst in roof above bathroom, taking out bathroom light, pull cord and shower pull cord.
The lighting is loop at the switch
I need to
1. make the light and pull cord safe, no access above for obvious
reasons
2. Install and 'temporary light to bathroom
My thinking so far is;
Mount shower cu as a sub main next to the cu (as it has no RCD and is ancient!) run cable in yt2 round to out side bathroom to a switch then through to suitable fitting mounted on bathroom wall.
Lighting solved!!
Disconnect shower at board, with draw MCB cut off cable to prevent reconnection, cut off at pull cord.
The customers son is organising a shower to be plumb off the combi boiler.
I need some how to make the 'old' lighting circuit safe (in the bathroom) if in deed the circuit is loop at the switch can anyone suggest how I can terminate the ends safely.
If not then i will have to extend the temporary lighting to other rooms.
Next thing is this is temporary, knowing the customers son it is likely to become 'permanent' this idea i am not happy with. Can I issue a cert for say 1 month and then say it will require regular checking until refurbishment is carried out.
Honestly I cannot think of a worse situation!!
Your advice and critisim will be much appreciated
Oh yes and to make things worse they are sort of 'relatives'
I need to
reasons
Lighting solved!!
