You failed to mention it was on your mothers side of the familyI am an electrician,
I am an electrician...
1. BS7671 does not permit this and never has.Why could you not pick up a neutral from another circuit
Lastly if anyone you who made comments are not qualified up to 16th edition then i suggest you keep comments to your self.
we're up to 17th edition nowadays.. so your 16th edition is useless now..
also, regs only doesn't make you an electrician..
you need experience and a practical qualification such as 236 or 2330..
so..
I connect my bathroom lighting neutral to the shower neutral..
and the shower neutral breaks or comes loose from the neutral bar for whatever reason..
the shower continued to work but you're neutral path for the 40 or so amps is now only 1mm² CSA...
THAT's why you can't do it..
