- Joined
- 10 Feb 2005
- Messages
- 64
- Reaction score
- 0
- Country
Hi all.
I'm after some advice. My existing fan assisted electric oven is supplied by the kitchen ring main via a 13A fused spur (I don't know what the existing oven is rated in terms of kW). The electric hob is on its own cct with a control unit and 32A MCB. All cables to the hob are 6mm^2. The power rating of the hob is 6.2kW.
I was suprised that the oven was on the ring main, but I have since read that this is OK provide the oven is less than 3kW. Is this correct?
Anyway, here's the thing. The oven is crap. It takes ages to heat up and is generally falling to bits. So a friend has given me an oven (Hotpoint BU62 if it helps)
The new oven is a double oven rated at 5.2kW. Is there any way I can have the hob and oven the same cct, with the existing wiring?
My trusty DIY book (1994!) suggests a 32A MCB and 6mm^2 wiring is good for "cookers" up to 16kW.
How is this worked out?
I'm thinking (new oven) 5.2kW + (old hob) 6.2kW = 11.4kW
11.4kW/240V=47.5A This say to me It can't... what am I missing?
Any advice on how I can make use of my 'new oven' would be much appreciated. Or would I be better off buying a replacement single oven that can run from a 13A supply and leave everthing as it is? What would you do?
PS I am skint
Thanks in advance,
Mark
PS I am skint
Thanks in advance,
Mark
