- Joined
- 11 Jan 2004
- Messages
- 46,752
- Reaction score
- 3,932
- Country
Rob, on that first piccy, why is there a switch marked "NOB"?
But remember, the isolation switch must be within 2 metres (or an armspan) of the appliance.
1/ If cables are chased into the wall from the switches on the ring above the worktop down behind the floor cupboard(s) which will house the socket/fllex outlets, do they just poke out of the wall through the back of the cupboard and into the sockets/outlets?
2/ The instructions with my 10 litre water heater indicate a fused spur connection from the ring should be used. Can I use a grid switch and just plug into a single socket instead, or should I add a 13A fuse to the grid and connect via flex outlet?
3/ Do fused spur connections/switches etc have to be above the worktop? If so, why?
Thus raising the other much debated subject of whether it's acceptable to fix sockets to kitchen cupboards....1/ If cables are chased into the wall from the switches on the ring above the worktop down behind the floor cupboard(s) which will house the socket/fllex outlets, do they just poke out of the wall through the back of the cupboard and into the sockets/outlets?
Yep. I just take the cable through the back of the cupboard straight into the socket.
Why make the fuse less accessible when you could have it on the grid?I'd put a fused spur in the cupboard to supply the water heater, but supply the fused spur from one of the switches on the grid switch.
There was a debate a while back on the iet forum about use of grid switches in this way as unless you run radials for each appliance, they are likely to be on a ring and it seems most grid switches are only rated for 20A not 32A.
I think the general consensus was that they wouldn't therefore comply.
SB
And BS 1363 sockets are rated at....?Yes electronicsuk - but on the ring side of the fuse (if you see what I mean) it could be up to 32A.
