We have a single skin porch on the side of the house.
Its constructed on the front and rear faces of brick. The side wall, which is against the neighbours wall with a 12" gap, is high density concrete block.
I removed the plasterboard which was batterned to the wall with a small air gap as they had mould growing on them . The rear face of the plasterboard was clean. The actual boards were damp as they crumbled easily when taking them off.
My question:
What is correct when re-fitting the porch?
Do I put a membrane against the wall, then insulate with double foiled celotex and then fit a vapour barrier under the plasterboard ( the alternative being foil backed plasterboard )
OR
Do I fit double foiled celotex to the wall, a vapour barrier and then plasterbaord.
Or
Do I fit double foiled celetex to the wall, tape the seems and then plasterboard.
I have read lots about allowing the room to breath, etc, but am confused about the correct way to do things.
Just to add to that - the porch is about 4m x 2.5m, is heated with a radiator, and has a door either end on the building.
Anyone?
My question:
OR
Or
Anyone?
